dreamer Posted April 23, 2014 Share Posted April 23, 2014 I think the the lighter and accessory socket in my car in not working. But can any one tell me how to check the fuse of the same? Link to comment Share on other sites More sharing options...
ian Posted April 29, 2014 Share Posted April 29, 2014 Hmmm. I see. I faced this problem once. My friend who has his own garage told me to do a simple circuit test. This test is basically to check the fuse in any part of the car Link to comment Share on other sites More sharing options...
dreamer Posted April 29, 2014 Author Share Posted April 29, 2014 Thanks for the reply. But can you please explain me how to do this circuit test. Link to comment Share on other sites More sharing options...
ian Posted April 29, 2014 Share Posted April 29, 2014 Sure. Take a test light and attach the clip end of the same outside the socket frame. The other longer point end of the tester and move it to the socket inside till it touches the back of the socket properly. If the test light blows, it means the fuse is perfect. If the tester doesn't lights up, it means you need to change the fuse and it will work again. Link to comment Share on other sites More sharing options...
dreamer Posted April 29, 2014 Author Share Posted April 29, 2014 Thank you. Will try the circuit test. Link to comment Share on other sites More sharing options...
