KiaDxb Posted March 25, 2011 Share Posted March 25, 2011 where is the cam shaft sensor located in this car i hope to get the answer before the week ends thanks in advance Link to comment Share on other sites More sharing options...
KiaDxb Posted March 29, 2011 Author Share Posted March 29, 2011 To Remove Camshaft Position Sensor 1. Disconnect negative battery cable. 2. Disconnect wire connector from sensor. 3. Remove sensor mounting bolts. 4. Remove the sensor from the rear of cylinder head. To Fit Camshaft Position Sensor 1. Install camshaft position sensor in rear of cylinder head. 2. Install and tighten sensor mounting bolts. 3. Connect wire connector to sensor. 4. Connect nagative battery cable. Link to comment Share on other sites More sharing options...
