steering oil change??
KiaDxb
Steering oil also known as PSF (Power Steering Fluid) usually need a top up after sometime. Change is required in major service of 40k kms.
Check the level and top up to see if it helps, then change the whole fluid. If still same that means your steering pump must be dying.
