what should i look for when buying a used car
darjey
i am planning on buying a second hand BMW 3 series i am not familiar with this brand. i want to know if the spare parts are expensive? , if owning a automatic transmission car good,how is the engine is it reliable, common issues with this car. what is the best time to buy this car summers or winter when can i get a better deal. how good is the cooling system of this car.
i will appreciate the advise.
regards
As a used buy, it makes excellent sense - but just because BMW has a peerless reputation for reliability doesn't mean there aren't pitfalls. There are quite a few ringers knocking around. Also, low-spec cars are nowhere near as desirable as those with better equipment, and only worth investigating if you are on a tight budget. It pays to shop around, as there is plenty of choice on the used market.
Checklist
* Side repeater lamps can work free from the bodywork and damage the wings. Check that they're secure.
* The most common fault on the E46 3-Series is with the heater blower fan. The switch breaks, meaning the fan will only work on its fastest setting. BMW dealers know of the problem, and will usually repair it free of charge (if in warranty).
* Be aware of high dealer repair costs. Also check condition of trim, as even minor parts are expensive.
No 3-Series is a bad buy. Entry-level cars are ideal if you are on a budget and aren't worried about resale values. Otherwise, go for a higher spec - alloy wheels are essential, as is air-con. Early 316s are slow, while larger en-gined models are expensive to run. If we had to choose a favorite it would be the 318i and 325 makes the most sense.
Search search and search for good car. Here are the few pros and cons of used BMW 3 Series.
The 3 series is definitely an enjoyable car to drive and also one of the best in its class. Road bumps and uneven surfaces can be noticed at slow speeds but the suspension is still of a good standard. This car is excellent for highway driving as it is so quiet. Whilst driving on highways you will hardly hear a thing from the road or suspension. Also, wind noise is only a slight problem whilst driving at high speeds.
In the vehicle there are plenty of adjustments to be made with regards to seating and the steering wheel. This increases the comfort factor. Controls are simple to use but higher spec models get the more complicated iDrive rotary control. The boot is one of the largest in its class and the back seats are comfortable unless you are over six feet tall, in which case the legroom will feel rather narrow.
From the range of BMW 3 Series every model comes with a powerful, silky engine. Basic models will come with air conditioning, a CD player and electric windows. You will find that main dealers have the best choice but if you are looking for a bargain a private seller may be a better choice.
The 3 Series can be an expensive car to run. You may have a shock when you see the costs for servicing and repairs. BMW dealers have some of the most expensive labour charges here in Dubai. The engines are fairly fuel efficient compared to its rivals. Insurance costs can be high if you are looking for a faster models.
