khandelwal Posted May 3, 2012 Share Posted May 3, 2012 I was just curious if I should set my car's maintenance to every year or something else? Also in case I don't do maintenance on my car, what are the problems that could possibly happen to it? Link to comment Share on other sites More sharing options...
khandelwal Posted May 3, 2012 Author Share Posted May 3, 2012 I am not really sure if this would help you or not but I have my car's maintenance (Change oil) every 3 months. Link to comment Share on other sites More sharing options...
KiaDxb Posted May 7, 2012 Share Posted May 7, 2012 I was just curious if I should set my car's maintenance to every year or something else? Also in case I don't do maintenance on my car, what are the problems that could possibly happen to it? there can be lots of things going bad and needs to be changed engine oil brake oil gear oil coolant brakes filters and other things you will only know when the car is checked and given for maintenance which i suggest that you give it at the earliest as the more u wait bigger the list will go. all the best Link to comment Share on other sites More sharing options...
