khandelwal Posted September 28, 2013 Report Share Posted September 28, 2013 Hello people, I recently got the oil changed of my sedona 05 .. the next day there was a huge leak where the oil filters are located. Its been two days now and I notice a leak every now and then. What can I look at in order to fix this problem. if its something I can do myself then well and good. Thanks Link to comment Share on other sites More sharing options...
khandelwal Posted October 2, 2013 Author Report Share Posted October 2, 2013 Hi aman, Do you have some basic knowledge about gaskets and seals? If so then you might be able to look into the problem yourself. You need to drain the oil, replace an oil filter and fix the valve cover gasket. You need to keep a look out for any signs of leaks while you are in the process of replacing and changing gaskets. And remember to warm up the engine a little before you begin so that the oil draining process is easier. If you have no idea what I am talking about then I guess you need to take it to have it checked Link to comment Share on other sites More sharing options...
khandelwal Posted October 2, 2013 Author Report Share Posted October 2, 2013 This visual has always helped me with my way around under the hood... see if you can use it to find the valve cover gasket, etc Link to comment Share on other sites More sharing options...
