red drops leak
sohailrangi
hi i have seen that there is a seepage on the line or red drops of Dexron on my garage floor that isn't coming from power steering pump or steering box. dnn knw where is it coming 4m
Are you using red or green coolant?
If red then it could be coolant so check all radiator and surround plumbing for any leak.
If 100% sure its dexron then it could be from gear oil too if its not golden one, hmm thts biggy. Better get it check all fluid level check and again check after two weeks and see which one deplete more. Rangie owner never complain of wet marks on garage as Range never leaks it just mark its territory. :lol:
