front drive shaft removal
jacktheripper
It must be pretty simple. For removing the front drive shaft, 4 bolts on each end. that's it.
If you are removing it for vibration at mid or high speed, then try changing the Universal Cross joint first at drive shaft. Thats the first to fail in line than the drive shaft itself.
