rubbing noise when coasting
praksh
when accelerating the car is just coasting which is is making a noise as if its rubbing
I checked the wheel and there is nothing loose which is rubbing up against the tires,
could there be anything else
Check the underbody if something is getting against the driveshaft or other moving part. May some plastic or heatshield hanging around and getting rubbed.
Discovery has notorious U joint on drive shaft. If in doubt disconnect front U joint and drive and see if noise disaapear then that means its the cross (u joint) you have to change.
