superseven Posted August 27, 2011 Share Posted August 27, 2011 When getting a flat tire i got it changed but the warning light is not going. what should i do? Link to comment Share on other sites More sharing options...
shaheen Posted August 28, 2011 Share Posted August 28, 2011 Step one : Make sure you have the correct tyre pressure in each tyre.Using iDrive Press menu button and then the start menu is called up. Step Two : Press the controller to call up the "I" menu and choose vehicle setting and press the controller. Step Three: Choose "RPA" and press the controller and Start the engine but do not move the car Step Four: Choose "tire pressure" and press the controller, Choose yes and press the controller Step Five: Drive off the message "Initializing" is displayed Initializing is completed during the journey. the control display then shows Status "RPA Active" again. This should stop your warning light from coming on Link to comment Share on other sites More sharing options...
