how can remove the brake sensor light after replacement?
Providing they have all been fitted correctly and the sensor wire replaced and plugged in + the brake fluid level is correct and sensor on the lid is correctly plugged in then the warning light will go out by itself after driving for a little while and braking a few times (don’t brake too hard for the first 100km though as you need the new brakes to bed in), if that doesn’t work disconnect the battery for a few minutes to reset the ECU, if that doesn’t work then re check all the sensor wires to ensure they are connected, if that doesn’t work then take it to triple A (AAA) workshop and they will find the fault and fix it.
Good luck.
