Landrover Maintenance Procedures - Common Additional Service
LandroverDxb
Land Rover Maintenance Procedures - Common Additional Services
Land Rover Air Filter Replacement
The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms.
Land Rover Automatic Transmission Fluid Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms.
Land Rover Automatic Transmission Fluid/Filter Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 50,000 kms.
Land Rover Brake Fluid Replacement/Flush
Brake fluid accumulates moisture and contamination from component wear over time and unless replaced every 50,000 kms or 2 years, can cause brake system damage.
Land Rover Coolant Replacement/Flush
Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms.
Land Rover Differential Fluid Replacement - Front
Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
Land Rover Differential Fluid Replacement - Rear
Land Rover Drive Belt(s) Replacement
Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms.
Land Rover Fuel Filter Change
The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to performance problems and early fuel pump failure. It should be replaced at the mileage interval recommended by the vehicle manufacturer.
Land Rover Rotate Tires
It is important to rotate the tires from front to rear every 8000-12000 kms so that they wear evenly. This may not be possible on some vehicles because of directional tread design or rim size differences.
Land Rover Spark Plug Replacement
Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval.
Land Rover Transfer Case Fluid Replacement
Transfer Case fluid breaks down and becomes contaminated with moisture over time and can lead to transfer case damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
  • 1 month later...
  • Carnity unpinned this topic
