zumba Posted September 24, 2011 Share Posted September 24, 2011 Why is my Land Rover Discovery not staying on after the initially start up? Link to comment Share on other sites More sharing options...
khalidh Posted September 25, 2011 Share Posted September 25, 2011 fuel is cutting off that is my guess but it is better to get it checked. Link to comment Share on other sites More sharing options...
Ghassan Posted December 13, 2011 Share Posted December 13, 2011 My 99 Disco1 used to get off sometimes while parking and twice when offroading the first time it did start after 15 minutes from trying everything and suddenly started again ! Battery is good , all wires and fuses functioning properly . The second misfortune was when it never started again been obliged with help of friends to tow it from fossil rock to Maliha and started the starter. And guess what it is working with no problem so far! Link to comment Share on other sites More sharing options...
bmwdoc Posted December 13, 2011 Share Posted December 13, 2011 could be fuel pump or even wires to the fuel pump, could also be a bad earth on the car, failed MAF sensor, Failed Crank position sensor, timing out, bad HT coil lead, in fact it could be a hugh number of things quite oftern a simple thing, take it to AAA or AtoZ garage they will find the problem for you Link to comment Share on other sites More sharing options...
