Morning Fewbie Plus Desert Drive (minimum 3 FB+ Drives) - Nahel Served Hot - Abu Dhabi - 16 Aug 2026
DP1011
DRIVE DESCRIPTION
Lets have a Summer Nahel Served hot drive - Meant for fast pace, so we exit before the temperatures hit what they could above 45 :)
Co-passengers - Certainly not more than 1 Co-passenger please.
A fast paced, Roller coaster, battling the soft sand !
Drive meant for members who have completed atleast 3FB+ Drives
⚠️IMPORTANT-PLEASE READ CAREFULLY AND COMPLY:
All participants must review and follow the club guidelines below:
🕖 DRIVE DETAILS
  • Level:  Fewbie Plus and above (Minimum 3 FB+ Drives Completed )
  • When: 16 Aug 2026, Sunday
  • Meeting time: 6AM - Sharp (Without any exceptions).
  • Meeting Point:  https://maps.app.goo.gl/fiUfRcs93UWP7KSu7
  • Approximate finish time: 9am
🚗VEHICLE REQUIREMENTS
  • Any proper 4x4 vehicle. If in doubt, please mention on the drive topic.
  • Front and rear tow hooks / recovery points.
  • 8–10 inches minimum ground clearance
🎒 WHAT TO BRING
  • Loads of water, snacks, smiles, enthusiasm and willingness to learn. We also recommend adequate protection from the sun and closed shoes.
🧰 OFFROAD GEARS
  • Tire deflator and Tire pressure gauge.
  • Air compressor.
  • A programmable Walkie-talkie radio.
  • Off-road safety flag.
  • A proper shovel.
  • First-aid kit and Fire extinguisher.
✅ RSVP
  • Confirm your attendance by clicking on "GOING" in the Calendar Event. Your name will appear on the RSVP list.
  • If the RSVP is full, add yourself to the waitlist. As soon as a spot becomes available you will be automatically moved to the RSVP list.
  • The RSVP closes approximately 1 day prior to the drive so the lead can finalize the convoy setup.
  • Latecomers will be turned back (no exceptions).
  • No RSVP = No Drive
  • Please withdraw your RSVP if plans change.
  • Repeated no-shows may result in 1-month suspension
PLEASE RSVP ON THE BELOW CALENDAR EVENT
Hi @Shane Phillips - Thank you for showing interest for this drive, unfortunately, I will not be able to accommodate you as this drive is a FB Plus with Minimum 3 FB+ Drives completed.
However looking forward to connecting you in one of upcoming drives.
P.S.: If Friday Noon works for you - There is one posted for FB level, by Ale.
Shane Phillips
I was promoted to Fewbie, I guess that is not enough. I think I will just quit the club as I am unable to join any drives suitable to my level.  There is also not that many drives on the club.
  • Sad (0) 2
Rajath Shetty
Hi @Shane Phillips, I was promoted to Fewbie level 8 weeks back and i have completed 8 fewbie drives so far which was announced & scheduled every weekend diligently. I suggest, if you could go through the community structure mentioned in the website. Hope this helps.
Cheers, Rajath
Dear Confirmed members - Thank you for showing interest- and we have some WL friends as well. hence, if any changes to your plans in next 2 days, Can I please request you to reflect that on RSVP :)  when you have visibility - If not , Looking Forward  to seeing you on Sunday !
Confirmed members
@nithish468 @Krinesh @Glenn W @ChrisW @Carl Stanley @Andrew John Melvill @Sebastian Nohse @Diego @Yury.bel @_Herman_
WL members
@Infaz @Nizar Shawwa @Eddie-Dune-Glider
  • Thanks (+1) 2
Dear @Sebastian Nohse & @Eddie-Dune-Glider - Apologies, I will not be able to consider you for this drive, as the track, pace and overall drive is planned for slightly experienced FB+ members i.e Atleast 3FB+ Drives completed, and I see you for you this is first and second FB+ Drive respectively, hence am afraid - However, I assure you these types of drives I often repeat and am deftly looking forward to having you - Thanks for your understanding  on this one !
Andrew John Melvill
This bunch of reprobates will make for an awesome drive!
Sebastian Nohse
1 hour ago, DP1011 said:
Hi Folks @Krinesh @Glenn W @ChrisW @Carl Stanley @Andrew John Melvill @Sebastian Nohse @Diego@Yury.bel@_Herman_ @Infaz @Eddie-Dune-Glider
Thanks to @Sam Selim  & @Asif Hussain who has kindly agreed to take one more convoy - We have No WL members and convoy order as below  : See you all at 6 for briefing. Please arrive little earlier, so you are deflated and flags up by 6, and we make the most of pleasant weather :)
Thanks for making this happen guys it is much appreciated!!
