Ghassan Posted January 7, 2012 Share Posted January 7, 2012 Thank you Joe. Will keep you posted !!! Link to comment Share on other sites More sharing options...
VCO Posted January 8, 2012 Author Share Posted January 8, 2012 desert sand is quite hard on air filter and everything behind I use CRC MAf cleaner from ACE , disconnect MAF and clean them with the spray . I also clean air filter box, connections, MAf to throttle boyn pipe. Its also a good ptacrice to clean up the throttle body with a carb cleaner ( everything is disconnected so its a easy 10 min job ) if you want to be sure about the maf just disconnect the MAF plug and disconnect bataery to reset ECU and see what happens Link to comment Share on other sites More sharing options...
Ghassan Posted January 8, 2012 Share Posted January 8, 2012 Thanks VCO' Link to comment Share on other sites More sharing options...
