Both the rear doors of my Range rover is jammed
asher
the rear doors are jammed for some odd reason. what tool should be used to open them and how can i stop them from getting jammed again
Door bolt must be jammed. If somehow you manage to open then make sure you load WD 40 in the door bolt which latches in. This mechanism must be jammed if not used for very long time.
If you cant open at all, then see a denter who can remove the panel and open the door and then open the door inside skirting and inspect what exactly is wrong and change that part.
