samey Posted March 27, 2011 Share Posted March 27, 2011 can i please have the procedure to remove the rear brake caliper on a Audi A3 Link to comment Share on other sites More sharing options...
shumarker Posted March 29, 2011 Share Posted March 29, 2011 This requires a special tool which spins the piston clockwise and simultaneously presses the piston in. This is do to the park brake system being incorporated into the caliper. If you can fashion a method to turn the piston with the notches on the face (portion that contacts the brake pad) and then push, turn, push, turn, etc. You may be able to get it in. This has the two V notches and will be difficult without the special tool. DO NOT scratch the sides of the piston as this is the sealing surface, and will then require replacement of the caliper. Link to comment Share on other sites More sharing options...
