vivekmazda6 Posted May 27, 2013 Share Posted May 27, 2013 Friends, I am having MAZDA-6 2005 model with 215000 mileage.bought from my friend as second hand. Recently i have noticed constant Check Engine Light Sign in the dashboard.I took it to Galadari Mussafah-Service centre-Abudhabi. They checked and told me that there is an issue with catalytic converter emission,so full silencer set has to be changed with the cost of 7500AED:-( .I couldnt spend this much as its closer to the value of the car . Can some one please help me to fix this problem. Where to approach? what to repair? how much it will cost?any good service centre in abudhabi? looking forward someones help. Link to comment Share on other sites More sharing options...
sunderdxb Posted June 2, 2013 Share Posted June 2, 2013 Go Mussafah again and see the small workshop who make or repair entire exhaust system and ask them to check for exhaust leak completely and fix it. I dont even think you need to change the exhaust. This engine light must be coming due to some minor and constant exhaust leak. I had a very similar issue, but no light and constant buzzing noise on highway speed. Got fixed in 50 dhs welding at 3 places, thats it. Link to comment Share on other sites More sharing options...
vivekmazda6 Posted June 3, 2013 Author Share Posted June 3, 2013 Hai thanks for your help. the problem is already fixed,I went to the exhaust repair area behind life line hospital,mussafah. i cleaned the oxgen sensor connector side with CRC cleaner for 20 dhs,and the check engine light has gone. May be if next time if check engine light comes again,i will go with what you said only. thanks, Link to comment Share on other sites More sharing options...
