battery is not charging
hamdaan
the battery is not getting charged so i replaced the battery as the alternator was working good.
the car was running fine for 2 weeks and then again the same issue happened the battery stopped charging again.
Your alternator isnt good and thats why after 2 weeks your car died on you as it has consumed all the battery.
For checking alternator, start the car and remove the battery cable and see. If car stall then that means alternator is dead.
