leak in transmission fluid
tomy
hi am an owner of mitsubishi Galant 2004 the automatic transmission’s oil cooler pipe is corroded and the , transmission fluid is seeping out due to a leak. this is what i have checked with my experience. i am not sure of the expense so i just wanted to knw if there is anybody else with the same issue so that i can have an estimate .
thanx
Transmision oil cooler isnt expensive, it must be around 300 dhs, and labour is another 100. Get it fix fast as it can fry A/T if not treated in time.
