keyen Posted May 16, 2011 Share Posted May 16, 2011 when recently getting my car serviced i got all my oils changed but just after a month the color of the engine oil looks questionable what is the reason for this Link to comment Share on other sites More sharing options...
lenon Posted May 20, 2011 Share Posted May 20, 2011 If you are doing too much doof doof and high rpm driving in eclipse its bound to happen. Still check the oil grade and viscosity as per OEM requirement next time you chnage oil. I suggest if in doubt get the oil change now and observe closely. Oil is cheap here and engine rebuild cost is fucking expensive. Link to comment Share on other sites More sharing options...
