engine oil going bad
keyen
when recently getting my car serviced i got all my oils changed
but just after a month the color of the engine oil looks questionable
what is the reason for this
If you are doing too much doof doof and high rpm driving in eclipse its bound to happen. Still check the oil grade and viscosity as per OEM requirement next time you chnage oil. I suggest if in doubt get the oil change now and observe closely. Oil is cheap here and engine rebuild cost is fucking expensive.
