viks Posted October 18, 2011 Report Share Posted October 18, 2011 My 2002 Mitsubishi Pajero's Display keeps flickering time to time. Link to comment Share on other sites More sharing options...
samesh Posted October 21, 2011 Report Share Posted October 21, 2011 Get the battery of your car checked first then the alternator. And if both look good then check the fuses. Link to comment Share on other sites More sharing options...
atifpop2k Posted July 12, 2012 Report Share Posted July 12, 2012 This is a common problem for all the Pajeros since 1991.. the sensors go mad very soon if you use 4x4 mode.. and then the display lights on the dashboard blinks like christmas tree lights.. Hope the company had a permanent solution to this. ! Link to comment Share on other sites More sharing options...
tkbery Posted July 31, 2012 Report Share Posted July 31, 2012 what was the reason did it get solved i have the same problem and the fuse is ok so now i think i will have to take her to the mechanic. Link to comment Share on other sites More sharing options...
karit Posted August 23, 2012 Report Share Posted August 23, 2012 my daughter was having a similar problem and what i found out was if the battery is good then the panel has to be changed altogether. Link to comment Share on other sites More sharing options...
tomy Posted August 28, 2012 Report Share Posted August 28, 2012 it can just be the panel lamp as well. Link to comment Share on other sites More sharing options...
debay Posted September 3, 2012 Report Share Posted September 3, 2012 My 2002 Mitsubishi Pajero's Display keeps flickering time to time. the same is happening. i am the owner of 2005 Mitsubishi Pajero and the dashboard light is blinking too much. what can i do i tried everything suggested here it is till happening. Link to comment Share on other sites More sharing options...
