Power Steering Fluid - Help!
Jruss86
Hello,
I own a 330i 2004 M Clubsport. I'm getting some whining noises in the steering usually in the morning, or after the car hasn't been used for a while. I'm keen on self servicing so I would love it if someone could help me find somewhere that sells bottles of power steering fluid. Castrol or whatever. I've tried Yellowhat, Epco stations and even BMW agmc, to no avail! Is there anywhere any of you can suggest??
Thanks, James.
Steering whining noise could be coz of older steering fluid or coz of weak steering pump. To start with changing the steering oil is better and cheaper fix, its normal PSF (Power steering fluid) same as use in auto gearbox. You can get Mobil 1 PSF or ATF (Auto Trans Fluid) very easily from karama (in Dubai) just before sana fashion if you coming from Garhoud side. Mobil 1 workshop is inside the emarat petrol station in the service lane.
  • 2 months later...
aishwarya wrote:
> The steering gear converts the turning motion of the steering wheel into
> the to-and-fro motion of the link rod of the steering linkage. Moreover, it
> also provides the necessary leverage so that the driver is able to steer
> the vehicle without fatigue. There are many types and makes of steering
> gears in use for automobiles. There are different types of steering gears
> namely
> 1) Worm and wheel steering gear
> 2) Cam and double roller steering gear
> 3) Worm and nut steering gear
> 4) Recirculating Ball Type Steering gear
> 5) Rack and Pinion steering gear
Thanks for the info, need my bmw servicing done and I am having a few steeing issues.
