mevin Posted January 26, 2011 Report Share Posted January 26, 2011 i have a 2005 altima which is having a window issue the window from one side wont go up or down, it looks like a funny triangle so i took the entire panel apart to see if the automatic power window motor is working or not which it did but the one side of the regulator had gone bad if i replace the regulator can i use the same motor. Link to comment Share on other sites More sharing options...
garfield Posted January 26, 2011 Report Share Posted January 26, 2011 ofcourse yes, if motor is working dont change. It just need proper re fixing, that it. Good luck with DIY. Link to comment Share on other sites More sharing options...
