rihan Posted May 22, 2011 Share Posted May 22, 2011 i have a 1998 sunny manual car and my issue with the car is that i am unable to engage the 3rd gear which is not a major problem othewise but when the car needs to start moving faster i need the gear and i have a feeling if i dont fix it on time i may fall in trouble how do i know if it is stuck or broken please help mee Link to comment Share on other sites More sharing options...
jamesd Posted May 23, 2011 Share Posted May 23, 2011 Better show it to some Gear professional like DEXOl and let them fix it. If its only third gear stuck it may be less cost in repair as only that gear teeth might have some issues, dont drive much as it will surely cost more if you ignore this first sign of gear failing. Link to comment Share on other sites More sharing options...
nimalp Posted August 27, 2011 Share Posted August 27, 2011 Also check if you have to change the transmission oil. It must be changed every 40,000 kilo meters at least. Link to comment Share on other sites More sharing options...
