what is the reason for getting ignition coil changed
amite
I was facing problems with starting the car and finally decided to take my Altima to the mechanic where he said Ignition coil is to be changed and he charged me 150 for consultation fees i want to know if this is a possibility and dont want to spend again in consultation fees.
the ignition coil is an important part of the car starting if you have any hesitation of the car then it should be changed.
It's not a wear item per say the coil usually lasts DECADES. but like all parts of the car they may not as well.
How will you know if the ignition coil has gone bad
If your car is misfiring you can unplug each coil one at a time with the car still running
Note if it makes a change.
IF this process dose not drop rpm then you have a bad ignition coil.
hope this helped solve your problem
