the Fuel Pump is not functioning well
faizan
i have just replaced the fuel pump and i have a feeling that the fuel is not reaching the carburetor. What are the indications that the fuel pump is working?
  • 3 weeks later...
Or by any chance you have clogged up fuel filter? Have you replaced it recently? If not, try replacing it should be cheap too. Check with the mechanic first if it is.
