sakid Posted July 8, 2011 Report Share Posted July 8, 2011 what could be the possible reasons for the engine cutting off? thanks Link to comment Share on other sites More sharing options...
premnath Posted July 10, 2011 Report Share Posted July 10, 2011 that are a number of reasons to this problem overheating, coolant leak fuel line problem exhaust problem and also you should be checking for vacuum leaks and make sure the IAC is working properly. IAC is idle air control.which is a solenoid that is responsible for maintaining engine idle. Link to comment Share on other sites More sharing options...
