bassim Posted February 21, 2014 Report Share Posted February 21, 2014 Hi everyone Just wanted to ask if i can refill the radiator coolant on my own. And if yes, then How? Link to comment Share on other sites More sharing options...
cyborg Posted February 25, 2014 Report Share Posted February 25, 2014 Yes you can! Make sure your engine is on but let it cool to the normal temperature. When you feel that the engine is at normal temperature, then open the radiator car and pour coolant in the same. Only thing that you ned to make sure is that the engine should should not be hot otherwise you may end up burning your hand. Link to comment Share on other sites More sharing options...
hemesh Posted February 26, 2014 Report Share Posted February 26, 2014 I did it too once. Just make sure that the engine is not hot when you are pouring coolant. Otherwise you may burn your hand. Just be careful, else the procedure is simple. Link to comment Share on other sites More sharing options...
