WHERE I CAN FIX MY A/C ??
dragenon
HI ALL .
I TOOK MY 307 TO THE WORKSHOP IN TASHIDEIA BUT THEY DONT FIX THE A/C .
ALL WHAT THEY DID IS CHANGING THE POLON FILTER . !!?
MY A/C DONT BLOW MUCH AIR. ONLY WHEN I PUT IT TO MAXIMUM . BUT IN OTHER POSTION IT WILL BE REALY SLOW AND LITTEL AIR FLOW.
DID ANY ONE KNOW WHY THIS HAPPEN ??
AND IF THERE IS A COMPONANT TO BE REPLACED PLEASE MENTION ITS LOCATION IN THE CAR .
GOOD DAY.
All caps is not very pleasant to eyes. Use for some hard and special emotions only.
For blower speed problem get to the electrician and get the blower checked with right amperage is coming or not? As with age if blower fan get old than it doesn't receive right electric amperage and hence runs slow. If its totally bad, then replace to new one.
Changing pollen filter was good idea as a first doubt because in many cases due to blocked pollen filter this slow air happen. Anyways don't regret pollen filter cost as it supposed to be changed every 2 years anyways.
  • 1 year later...
hi,
is there any news about this issue did the electrician manage to fix the issue for you ?
if so please tell me where did u go and how much did it cost you as am facing the same problem.
Thanks.
