Why clutch fails!
amid
Hey guys
I am really passionate about knowing the mechanism of cars. Recently I was browsing about manual transmission car and the common problems in the manual transmission, and its clutch mainly. Please discuss about the common reasons why do the clutch fail?
The most common reason of clutch failure is the oil leak. If this is the case, then one should never replace the clutch until and unless the oil leak is fixed.
Another reason can be bearing not installed properly. In such a case, the driver should not rapidly ride the clutch every time.
I suppose these are the common clutch failure in a car. Please share if others know more. Thank you
