noisey car
unni
when driving my 2002 boxter on the side o the road there is noise from the underneath of the car but when in the middle the noise goes off then again after 45min to an hour the noise comes back
i have checked suspensions breaks and nothing is loose to make that kind of noise then what can it be
thanks
If sounds 100% due to shock absorber isn't very nice and squeaking. But still check for steering system components like lower arm control rod, connecting rod etc isn't loose and making some noise on highway.
  • 1 month later...
If it is a clunking type sound. I once had a problem on one of the boxsters i had. I found the problem to be a loose arm in the roof bay.
Depends what type of sound really and how and when it happens. Seek a mechanic if its causing some driving problems.
