sambanker Posted March 16, 2012 Share Posted March 16, 2012 every time i steer my Cayman to right it makes noise. what can i do? Link to comment Share on other sites More sharing options...
milane Posted March 24, 2012 Share Posted March 24, 2012 Check the axle boot, it may need change if its torn and out of grease. If its really bad then im afraid your this clicking is due to damage axle. Link to comment Share on other sites More sharing options...
qinsley Posted April 29, 2012 Share Posted April 29, 2012 In power steering check the power steering fluid level. The groan is usually an indication that the power steering fluid is at a low level. Link to comment Share on other sites More sharing options...
Fahadriz Posted April 29, 2012 Share Posted April 29, 2012 Yes that's correct. Check the power steering fluid level. It doesn't give a warning indicator so you never realize its gone down. Link to comment Share on other sites More sharing options...
qinsley Posted April 30, 2012 Share Posted April 30, 2012 Tell us if this has fixed your problem if not then it could be something else. We can do more TS if that was not the issue. Link to comment Share on other sites More sharing options...
Fahadriz Posted April 30, 2012 Share Posted April 30, 2012 Yes it fixed it. Link to comment Share on other sites More sharing options...
ronak Posted August 29, 2012 Share Posted August 29, 2012 what was the reason for the steering noise. If you dont mind telling? Link to comment Share on other sites More sharing options...
