hasmukhpatel Posted June 3, 2011 Share Posted June 3, 2011 after the thermostat was resting next to H i got it replaced and even changed the coolant temp sensor but after that the thermostat still remained on H. now what to do Link to comment Share on other sites More sharing options...
chandrakumar Posted June 5, 2011 Share Posted June 5, 2011 I hope thermostat is not at H after driving fo few minutes, that means car is damn HOT. If it resting thru out at H, then its a faulty gauge at dashboard and its a little expensive fix to change the instrument cluster. See in shj if someone can repair that. Before that check all fuses and relay too. Link to comment Share on other sites More sharing options...
