how to change the thermostat
wazeer
Overheating indicate, in efficient cooling system. Which consist of: ( may be)
Radiator blocked or choked
Radiator leaking
Radiator coolant reservoir bottle leaked and cant suck coolant when needed
Check radiator and radiator bottle caps. It shud be air tight.
Check thermostat if its opening and closing at right temp
Check Viscose clutch fan (radiator BIG fan)
Check AC fan (small one)
Check water pump
Check alternator.
  • 3 weeks later...
Black hose going from radiator to engine have thermostat in between just before engine jacket. Just open and replace its an easy 10 min job. Dont forget to put the seal or sealant where thermostat sits.
