Best fuel efficient car
rex
Hi all, i was reading an article on 2013's most fuel efficient cars and the first place goes to the toyota prius plug-in 2013, followed by the toyota prius 13 and then the prius c 13. Basically establishing that the toyota prius line-up is the most fuel efficient choice when it comes to fuel efficiency in 2013. What is so special about this car?
Also who disgarees?
Fuel efficiency is determined by the different engine combinations offered by car brands but at the end of the day everyone has to agree that fuel efficiency majorly depends on the driver's skills and behavior of driving. Fullstop.
As much as i would like to say that this mid-sized hybrid is great innovation but sooner or later we all knew that this one car will enter into the market which can be charged up with an electric outlet. the plug-in is not a place for UAE where you can hardly park your car for a recharge at an outlet. The normal prius can do well though.
Considering the technology these cars run on ... yeah they are bound to be fuel efficient - Heck the plug-in might not require gas at all for some people! hehe
Heard the plug-in received a couple of awards and good ratings too. ummm ... a car with a plug. Already hate charging my mobile over and over again wonder how people are going to deal with charging a car!
The toyota prius is basically a hybrid which was designed to run on the most reduced emissions system. When we drive a car, fuel is used at every point and toyota designed the Toyota hybrid system to discontinue this trend. it primarily focused on powertrain for its running.
The engine basically only starts when it achieves a particular speed so hence it accelerates on electric load. Another thing about the prius is that The gasoline engine can be tuned in order to use a customized gasoline engine.
