engine oil is vanishing
esa.balushi
after recently getting my 2004 polo serviced the oil started vanishing and there are no traces of oil leak
i even got the filters , all the oil and timing belt changed
what should i do now
If you are seeing excessive smoke then that means engine oil is getting burnt inside the combustion chamber. Reason for this leak piston rings is leaking the oil and needs to be change. Which is a very big job to open whole engine and remove the piston to change the piston rings.
  • 4 weeks later...
