Battery Corrosion
crackjack
  • 2 weeks later...
Battery corrosion is a big issue sometimes. i know there are some sprays that you get in the auto shop to remove the corrosion. You can use that.
  • 3 weeks later...
Baking soda is the best thing you can remove the corossion with. Take baking soda and spray it to the terminal or clamps where you see corossion. Wear gloves in your hand. You can use either the lint free cloth or a tooth brush to rub the baking sods to the corossive surface. wash it thorougly after some times and put petroleum jelly to avoid any further corossion in the near future.
