AC Condensation
fardin
Hey people. I am driving Toyota Corolla 2007 model. These days, the AC condensation is having an issue. So i wanted to ask if I can fix the Ac condensation on my own? If yes, then How?
  • 2 weeks later...
The general issue with the Ac compressor is the condensation line clogging. When we use the AC, offcourse the air is cool but muc dryer than normal air. In such a case, there is condensate clogging inside the AC. To remove the clogging, you just need to unscrew the drain pan and clean your AC inside out with Wet and dry vacuum. Make sure that the engine is off when you do that. Its easy to clean the AC drain area, just make sure to remove any kind of dirt you feel there is. And the Ac will be fine.
  • 4 weeks later...
I did the cleanign as you said. Uffff! the odor and the amount of dirt from the pan was horrible. But after cleaning it, the AC is perfectly fine. No clogging at all. Thanks to you actually!
