bradly Posted July 20, 2014 Share Posted July 20, 2014 There is too much smoke coming out from my XA, 2007 model. Someone please tell me why is it happening? Link to comment Share on other sites More sharing options...
dannys Posted August 6, 2014 Share Posted August 6, 2014 I think the egine os overheated. Try to touch the engine dash, If you feel is too much heated then may be the engine is overheating. Its bad dude. Open the engine for a while and wait till it cools down. I think there is some leak in the engine. Check for the leaks using the smoke machine. Link to comment Share on other sites More sharing options...
bradly Posted August 6, 2014 Author Share Posted August 6, 2014 Ummm ok. But are you sure it’s because of overheating. And is it a big money to resolve this issue. Link to comment Share on other sites More sharing options...
dannys Posted August 6, 2014 Share Posted August 6, 2014 Well I think is because of overheating. If your engine is too hot and there is smoke coming out, then yes it’s overheated. Cost of repairing it actually depends on from where the leak is. You might have to get some auto parts replaced. Link to comment Share on other sites More sharing options...
bradly Posted August 28, 2014 Author Share Posted August 28, 2014 You guys were right i suppose. The radiator was too hot. I took the car to the dealer, and they said that the coolant was leaking. Don even ask the repair cost. They had to chage the head gasket and the radiator. Link to comment Share on other sites More sharing options...
ghassank Posted May 14, 2015 Share Posted May 14, 2015 Doolant leaking can be a serious problem, It was a good idea to visit your dealer. This repair would've cost you much more in one month. Link to comment Share on other sites More sharing options...
