Rear tire wearing out
How old is your tire?
If its more than 5 years, then its the time to change your tires. If the tires are still new, it means you are somehwere not taking proper care of it. May be keeping heavy things in the car, that also affects the performace of the tires.
  • 9 months later...
This is really unusual. I suggest you check your tires in a garage. It is typical for the front tires to get worn out over time. It is probably some mechanical reason.
