nackjack Posted August 5, 2014 Share Posted August 5, 2014 The rear tire of my car is wearing out. Why is it happening so frequently? Link to comment Share on other sites More sharing options...
danish Posted August 7, 2014 Share Posted August 7, 2014 Don’t drive on off-roads or potholes. Maintain the tire pressure regularly Or maybe the wheel alignment is not proper Link to comment Share on other sites More sharing options...
kris Posted August 10, 2014 Share Posted August 10, 2014 How old is your tire? If its more than 5 years, then its the time to change your tires. If the tires are still new, it means you are somehwere not taking proper care of it. May be keeping heavy things in the car, that also affects the performace of the tires. Link to comment Share on other sites More sharing options...
girix Posted May 12, 2015 Share Posted May 12, 2015 This is really unusual. I suggest you check your tires in a garage. It is typical for the front tires to get worn out over time. It is probably some mechanical reason. Link to comment Share on other sites More sharing options...
