sufi Posted December 10, 2014 Share Posted December 10, 2014 Someone told me that old tires starts leaking air sometimes. Is that true? Link to comment Share on other sites More sharing options...
neelam Posted January 2, 2015 Share Posted January 2, 2015 Ya, Its true Link to comment Share on other sites More sharing options...
kris Posted January 4, 2015 Share Posted January 4, 2015 The logic is very simple on this. If your tires are really old, then of course you must have driven your car on potholes and sometimes off road too. So basically when you are driving your car from a very long time with same original tires, they intend to loose their attributes after couple of years. If the tire pressure is not maintained properly it causes inflation i the car and it may turn up to leaking air from car. That is why it is strogly recommended that should take care of the tires properly and maintain the pressure in the same. Always take guidance from the service centre if the tires of your car needs to be replaced. Link to comment Share on other sites More sharing options...
jabri Posted March 26, 2015 Share Posted March 26, 2015 People actually need such common sense info to be told..... Link to comment Share on other sites More sharing options...
gshane Posted April 15, 2015 Share Posted April 15, 2015 Of course, it's true. The materials loosens and that's why you should avoid buying very old tires even if they are new. Link to comment Share on other sites More sharing options...
