deve Posted April 2, 2015 Share Posted April 2, 2015 I was reading somewhere that P cars do burn some good amount of oil, is that true? I'm sure turbo-cars do burn oil by a lot! can someone let me know? if thats true or not - I'm thinking to purchase P car soon, thanks! Link to comment Share on other sites More sharing options...
leey Posted April 3, 2015 Share Posted April 3, 2015 I think that every turbo-charged car burns oil a little, if its too much, check turbo seals Link to comment Share on other sites More sharing options...
gshane Posted June 1, 2015 Share Posted June 1, 2015 I agree with leey. It is quite natural for turbo-charged cars to burn some amonut of oil. It also depends on the way you drive your car. In my opinion, this is not something that you should worry about. Link to comment Share on other sites More sharing options...
bean Posted June 1, 2015 Share Posted June 1, 2015 On an average if burns around 1 liter every 1000-1200 kms then it's very normal. Some old turbo porsche may burn within 800 km due to ageing turbo and weaker seals. Any other lower numbers are worrisome. Link to comment Share on other sites More sharing options...
Saleem Posted June 11, 2015 Share Posted June 11, 2015 Hi every internal compassion engine burn oil but the burned quantity vary upon condition and specs. and all sporty driving and high rives burn oil and it's even mentioned on owners manuals to top it up within specs of use and short quantity. please specify which Porsche are you looking for. Link to comment Share on other sites More sharing options...
taqir Posted June 12, 2015 Share Posted June 12, 2015 As per theory, no oil should get burn't in engine if it is not turbo. In turbo due to high pressure it get's consumed. Oil level should stay same or reduce very very marginal in service internal, if major reduction in oil level then it's a leak in the engine or down the sump area (engine oil area). 1 Link to comment Share on other sites More sharing options...
Saleem Posted June 13, 2015 Share Posted June 13, 2015 Hi Taqir That is true but with the specified operating lubricants and temperatures! It did exceed 50C last couple of weeks several times! do you think Mobil 1 would survive on these operating situation? Link to comment Share on other sites More sharing options...
taqir Posted June 13, 2015 Share Posted June 13, 2015 Hi Saleem, Engine Oil flash point is in range of 200 - 250 C depending on brand and viscosity you choose and outside temperature rising from 40-50 has very less co-relation IMHO. https://www.micapeak.com/info/oiled.html Link to comment Share on other sites More sharing options...
