Mach3 Posted May 28, 2015 Report Share Posted May 28, 2015 Is it better to swap the engine in this car model or to rebuild the engine? Which option is easier and more cost affordable? Link to comment Share on other sites More sharing options...
adil Posted May 28, 2015 Report Share Posted May 28, 2015 Swapping is always advisable than rebuilding it, as it will cost lesser. You should only rebuild engine if you dont find good swap donor engine or it's a super special car on which you know the full history of engine. Rebuilding rule is always applied second, as after rebuilding no one get 100% same performance, unless you are rebuilding engine for performance gains with performance parts. Lot of people claim that they rebuild good, but ask them if they can get 80-90% performance of factory sealed engine.....? Link to comment Share on other sites More sharing options...
bean Posted May 31, 2015 Report Share Posted May 31, 2015 Well it's not always, adil. If you get the rebuilding done properly from dealership you will not experience any difference and its better that way if your car is low mileage. If engine done above 150k - 200k, I agree swapping is better than rebuilding the old and tired engine. Link to comment Share on other sites More sharing options...
