aftaab Posted January 29, 2011 Share Posted January 29, 2011 the exhaust is having a bit of leaks dose that mean that i need to change the entire cluster or the holes can be repaired. thanks Link to comment Share on other sites More sharing options...
akshayasingh Posted January 29, 2011 Share Posted January 29, 2011 Holes can be welded, but it might come back again as the exhaust metal is getting weaker, if its older car better change the exhaust. If its new car (less than 5 years) then get it welded, it might have got hole due to some stone hit there. Link to comment Share on other sites More sharing options...
renskys26 Posted April 18, 2012 Share Posted April 18, 2012 if the noise is from exhaust manifold (engine area) check the year model of your vehicle cause starting 2008 model there is a special coverage warranty given by GM, it would be better if you visit any Chevrolet dealer. Link to comment Share on other sites More sharing options...
ihabb Posted May 25, 2015 Share Posted May 25, 2015 You can patch the holes but it is recommended to change the entire cluster. This intervention is not difficult or costly. Link to comment Share on other sites More sharing options...
