mathur Posted June 25, 2011 Share Posted June 25, 2011 after I replace rear tie rods on an Audi A4 2001 the car seems to wobble i an very sure that the installation was done correctly. what should i do Link to comment Share on other sites More sharing options...
pokerface Posted June 26, 2011 Share Posted June 26, 2011 Check the link rod that ends at toe rods. Old one might be broken but just fitted there to avoid any wobble. While you change the toe rod that link rod bush must not be sitting in same place and hence calls for new link rod. I doubt if you can just replace the link rod bushes, that can actually fix the problem. Link to comment Share on other sites More sharing options...
