J J Posted June 24, 2020 Share Posted June 24, 2020 Question for the Jeepers - Have you used a pedal commander ? I know its only faster throttle response and no real stat change on the performance - Do you feel a significant difference/ advantage when off -roading or on city drives. 1 1 Link to comment Share on other sites More sharing options...
Frederic Posted June 24, 2020 Share Posted June 24, 2020 48 minutes ago, J J said: Question for the Jeepers - Have you used a pedal commander ? I know its only faster throttle response and no real stat change on the performance - Do you feel a significant difference/ advantage when off -roading or on city drives. It's actually available for many cars, not only Jeeps. It alters the original signal from the throttle pedal to the ECU, and amplifies this signal to create a kind of "boost" feeling like if you would floor the pedal immediately. (based on the mode you choose of course). Eco mode does the opposite and numbs down your throttle behavior so the car behaves a bit less responsive. I have seen the reviews and tests, but in my opinion Sports mode becomes a bit aggressive for the vehicle, and potentially might damage drive-train components. There is a reason why the original manufacturer tunes the throttle response to the vehicle. 3 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Febin Frederic Posted June 24, 2020 Share Posted June 24, 2020 personally i feel, its not worth it. it can potentially damage your throttle body. id rather go old skool.."pedal to the floor". 1 3 Link to comment Share on other sites More sharing options...
