maguire Posted April 13, 2011 Report Share Posted April 13, 2011 where is the fuse for fuel pump located in 1999 1.4 ltr Link to comment Share on other sites More sharing options...
chian Posted April 14, 2011 Report Share Posted April 14, 2011 There is no fuse for fuel pump, however it has fuel pump relay The fuel pump relay is mounted under the dash on the drivers side. Test current draw with ignition "ON" and bridge terminal 1 Yellow/Black wire to terminal 2 Green/Yellow wire and the fuel pump will run. Link to comment Share on other sites More sharing options...
